New Posts New Posts RSS Feed: Rule 17 and the definition of proper course
flaming View Drop Down
Post Options Post Options   Quote flaming Quote  Post ReplyReply Direct Link To This Post Topic: Rule 17 and the definition of proper course
    Posted: 30 Aug 16 at 10:59am
2 One design Asymmetric yachts are running downwind on their best VMG angle on Port Tack.  They are above their layline to the next mark and will need to gybe to reach it.
PL is borderline overlapped and about 1 boat width to leeward, the exact relationship is however unimportant (bear with me) but it is clear to all that PW cannot gybe until PL does without breaking rule 15.
They gradually approach from clear astern a Symmetrical Boat, also on Port Tack, who is running deeper to the same mark and will not need to gybe.  The Symmetrical boat is not racing PL and PW, so the Symmetrical boat does not defend but simply wishes them to get on past as soon as possible.
PW passes to windward of the Symmetrical Boat, but for reasons known only to themselves, PL establishes an overlap within 1 boat width to leeward of the Symmetrical Boat.  Who sighs with frustration and comes up to match the course that both PL and PW have been maintaining before they established the overlap.
PW sees this as a golden opportunity to break the control that PL had over them, and reacts by going very high, clearly intending to create enough space to gybe onto Starboard.
PL reacts by altering course towards PW, heading up far higher than their previously maintained course, in order to try and stop them gaining the separation they would need to execute a gybe.  A debate about proper course breaks out between PL and the now very annoyed Symmetrical boat, who points out that they are being taken higher than the course PL was sailing before they established the overlap a course that they had been sailing for some minutes previously and that matched the course of the other identical boats in sight, and a course that has resulted in both boats sailing away from the mark and struggling to keep kites flying. The Symmetrical boat never the less reacts to PL's luff and keeps clear.
The definition of PROPER COURSE says "A course a boat would sail to finish as soon as possible in the absence of the other boats referred to in the rule using the term."
There is no doubt that without the symmetrical boat PL would have reacted to PW's manoeuvring by going with them, they were basically match racing for a place on the final meaningful leg.  (The next mark being a leeward mark followed by a very short fetch to the finish).  But without the symmetrical boat PW would not have done that.  It is also true that heading up in this way is not the course for PL to finish as soon as possible, as it is clearly away from their best VMG it's just a course that might enable them to finish in front of another boat.
Question.  Did PL break rule 17?
Presuming Ed View Drop Down
Post Options Post Options   Quote Presuming Ed Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 16 at 11:04am
Short answer:
Yes.
jeffers View Drop Down
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 16 at 11:53am
Agree with Ed. PL would not have done that if the Symmetric spinnaker boat was not there. PW was free to do as they pleased pretty much as long as they kept clear of the Symmetric boat and PL (so going high to create space and gybe is a good tactical call IMO given PL's mistake).
D-Zero GBR188
Ex Rooster 8.1 '11'
Ex Laser 167534
Ex Blaze 655
Post Options Post Options   Quote flaming Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 16 at 2:48pm
But could they not argue that they would have gone high if Symmetric wasn't there if PW had sailed that course?
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 16 at 3:00pm
They could argue that, but I think they'd lose the protest.
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 16 at 3:05pm
They could argue whatever they like, the definition of Proper Course is 'in the absence of other boats' so PW's actions are immaterial.
D-Zero GBR188
Ex Rooster 8.1 '11'
Ex Laser 167534
Ex Blaze 655
Brass View Drop Down
Online Status: Online
Post Options Post Options   Quote Brass Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 16 at 3:08pm
Point is, Proper Course is to finish 'as soon as possible' not 'in front of a competitor'.
Post Options Post Options   Quote flaming Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 16 at 3:10pm
Thanks.  That clarifies it in my mind!
Post Options Post Options   Quote Presuming Ed Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 16 at 4:09pm
[Pedant hat] Minor point, but it's "a course a boat would sail to finish as soon as possible in the absence of the other boats referred to in the rule using the term...."
So take this scenario below, and saying that 17 applies between yellow and blue. When determining yellow's proper course, we can "remove" blue and see what that does to yellow's course. But yellow's proper course is to avoid green, so even though she sails higher than before, she doesn't sail higher than her proper course, and doesn't break 17.
[/Ph]
Edited by Presuming Ed - 31 Aug 16 at 4:12pm
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 16 at 4:46pm
[/Ph]
As yellow is going to windward of green in your example she is not subject to Rule 17 with regards to Green though. Green however can use rule 11 should she choose to make life difficult for Yellow (and possibly Blue).
D-Zero GBR188
Ex Rooster 8.1 '11'
Ex Laser 167534
Ex Blaze 655
