Centreboard case coating |
ian.r.mcdonald
Far too distracted from work Joined: 24 Feb 06 Location: United Kingdom Online Status: Offline Posts: 440 |
Topic: Centreboard case coating Posted: 04 Aug 16 at 6:49am |
I need to recoat the inside of the centreboard case on my wooden Osprey, just repair the wear of 20 years of centreboard movement. There are no gouges or water ingress but I want to get it sorted before this happens. What is the best coating? Is it best to apply with the boat on its side to avoid runs or will I be ok (with radiator roller) to do it without runs with the boat upright and case surface vertical?
PeterV
Posting king Joined: 24 Feb 07 Location: United Kingdom Online Status: Offline Posts: 131 |
Post Options Quote Reply Posted: 04 Aug 16 at 12:17pm |
I've just done both daggerboard casings on the catamaran I'm restoring. I sanded down the casings first with sandpaper wrapped around a batten. I then used a small roller on a long handle from Wickes and Timberseal PS epoxy. As the boat was upside down I got some runs on the decks but none inside the cases. Seems to have worked very well.
PeterV
ian.r.mcdonald
Post Options Quote Reply Posted: 04 Aug 16 at 5:02pm |
thanks Peter, that gives me confidence not to mess about with the boat on its side
Post Options Quote Reply Posted: 04 Aug 16 at 7:33pm |
Dunno, if the manhandling can be managed safely there's an awful lot to be said for working on a boat on her side. Access is so much easier - and kinder on the back.
cad99uk
Posting king Joined: 11 Mar 10 Location: United Kingdom Online Status: Offline Posts: 187 |
Post Options Quote Reply Posted: 04 Aug 16 at 7:55pm |
+1 |
