New Posts New Posts RSS Feed: Rule 18 Question
Rule 18 Question
NickM View Drop Down
Post Options Post Options   Quote NickM Quote  Post ReplyReply Direct Link To This Post Topic: Rule 18 Question
    Posted: 19 May 16 at 10:13pm
A and B are approaching the leeward mark on a broad reach. A is ahead of and to leeward of B. B establishes a minimal overlap on A at three boat lengths but slows and the overlap is broken (agreed 18.2.c.1 still applies.)
If A is far enough ahead to round the mark "normally" without impeding B's own normal seamanlike rounding, can she do so, or does she have to sail wide round the mark leaving what is in effect an empty lane inside her for B to full moments later when she arrives?
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 16 at 10:31pm
As is so often the case go to the definitions...
Mark-Room Room for a boat to leave a mark on the required side. Also,
(a) room to sail to the mark when her proper course is to sail close
to it, and
(b) room to round the mark as necessary to sail the course.
So there's nothing in the definition that says how you have to give room, and if a faster boat gives the room by being clear ahead then I believe that's ok. But if you slow during the rounding you could be in deep trouble.
Post Options Post Options   Quote NickM Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 16 at 10:35pm
Thanks Jim. That's how I had understood it but good to have your expert confirmation.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 16 at 6:01am
I need to contest expert. I'm far from that.
