New Posts New Posts RSS Feed: 420Jib sheet length
420Jib sheet length
JMORRISSEY View Drop Down
Post Options Post Options   Quote JMORRISSEY Quote  Post ReplyReply Direct Link To This Post Topic: 420Jib sheet length
    Posted: 29 Nov 15 at 2:17pm
Afternoon all.
Can anyone tell me how much dyneema I need to buy for the jib sheet on a 420.  Its missing.  Is 8mm enough or do I need 10mm?
Here goes my learning to sail midlife crisis
Time Lord View Drop Down
Post Options Post Options   Quote Time Lord Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 15 at 3:42pm
Go to pinbax.com and hit the Fleet button on right hand side of page. Go to 420 and you will find that they offer made up tapered jib sheets. Alternatively give them a call and ask the question.
6mm is more than adequate if you want to be kind to the crew. Usually theń tapered down to 3.5 mm.
Merlin Rocket 3609
Post Options Post Options   Quote JMORRISSEY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 15 at 7:29pm
Cheers.  Thank you.
Post Options Post Options   Quote Time Lord Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 15 at 8:32pm
You're welcome. A further thought - in Merlin's and many other classes the fashion these days is to have one jib sheet with both ends attached to the jib clew and then run back through each jib cleat and across the centre of the boat - easier to do than describe. Just think of the old style of two separate jib sheets knotted together in the centre of the boat.
This method allows the crew to easily pick up the leeward jib sheet when hiking out to windward and saves having to move across the boat when their weight needs to be out to windward.
Merlin Rocket 3609
Post Options Post Options   Quote JMORRISSEY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 15 at 10:18pm
Thank you.  That makes perfect sense.   Means you are not chasing loose ends around the boat.
