New Posts New Posts RSS Feed: cover cleaning
cover cleaning
mangoman View Drop Down
Post Options Post Options   Quote mangoman Quote  Post ReplyReply Direct Link To This Post Topic: cover cleaning
    Posted: 17 Nov 15 at 1:53pm
The boat has come home for the winter ( can't find anywhere in Norfolk close enough to home to sail through the winter  Cry ) and the cover needs a good clean. Covered in green stuff.
What is the best stuff to clean the cover with ?
Thanks
Buzz View Drop Down
Post Options Post Options   Quote Buzz Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 15 at 1:58pm
I lay the cover on the ground and use a pressure washer.
Post Options Post Options   Quote mangoman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 15 at 4:58pm
Good idea ! Thanks
Time Lord View Drop Down
Post Options Post Options   Quote Time Lord Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 15 at 5:23pm
You can also use the spray that the diy shops sell for removing mould from walls. Good at getting rid of the green mould provided that it is all washed off afterwards.
Merlin Rocket 3609
tgruitt View Drop Down
Post Options Post Options   Quote tgruitt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 15 at 5:40pm
You could give it to a sailmaker to put in their big washer/dryer machine!
The Moo View Drop Down
Post Options Post Options   Quote The Moo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 15 at 7:03pm
Or someone in the equestrian world who cleans horse blankets.
cad99uk View Drop Down
Post Options Post Options   Quote cad99uk Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 15 at 7:33pm
Cif and a scrubbing brush. Rinse off.
Noah View Drop Down
Post Options Post Options   Quote Noah Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 15 at 8:39am
I've used domestic detergents, hosepipe and a stiff brush in the past.
Whatever cleaning method is used, it'll likely need re-waterproofing afterward, unless its PVC of course, in which case the cleaning will be easier too!
Oli View Drop Down
Post Options Post Options   Quote Oli Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 15 at 1:07pm
HG mold cleaner plus pressure wash makes it like new.
Post Options Post Options   Quote mangoman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 15 at 2:51pm
Thanks for that suggestion; one concern, does this product bleach the colour out of the cover ?
