New Posts New Posts RSS Feed: RS200 Thwart
RS200 Thwart
Granite View Drop Down
Post Options Post Options   Quote Granite Quote  Post ReplyReply Direct Link To This Post Topic: RS200 Thwart
    Posted: 19 Oct 15 at 12:36pm
Does anyone have experiance of removing the thwart from an RS200?
I have an older 200 and there is a crack in the thwart about mid span. I could repair in situ but getting a neat repair on the underside will be a bit of a pain. I can see that there are screws attaching it, so thorecically it should be simple to remove, however if it has been bonded in as well as the screws it might not be worth the effort.
Any thaughts?
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 15 at 3:33pm
Talk direct to RS and see what they think.
jaydub View Drop Down
Post Options Post Options   Quote jaydub Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 15 at 3:34pm
Speak to Mike Saul from MSDS, who is the Northern RS Dealer.  Mike is good at providing pragmatic advice and will also quote for the job should you not fancy doing it yourself.
JP Watersports are the Scottish Dealer and may also be worth a shout.
sargesail View Drop Down
Post Options Post Options   Quote sargesail Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 15 at 9:57pm
What do I think - I think you've changed Phil!  I would slap some bog or some mat on the underside and forget it was there!  Did you learn nothing with those Laser 2s and in your Cherubs?
Post Options Post Options   Quote Granite Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 15 at 1:47pm
Matt,
The plan is to slap a patch on the underside, however it is difficult to see what I am doing can be difficult to get the patch to stick in place while it cures. If removing the thwart is just a couple of screws then it would be eisier to do on the bench. However if I need to battle against a thick layer of sealent to get it out then it would be eisier in situ.
Fixing all those boats I have learned to try to make life easy for myself
Online Status: Online
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 15 at 2:01pm
I have a feeling its partially glued, how well its still stuck might be another matter. The job is going to be so much easier with the thwart out that isn't it going to be worth investigating whether its reasonably straightforward to remove it? Probably worth half an hour removing the thwart even if you have to replace the filler...
craiggo View Drop Down
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 15 at 3:34pm
Lift your boat up in your boatshed/garage in some suitable strops upside down, and work on the repair the right way up.
Edited by craiggo - 21 Oct 15 at 3:35pm
Graduate 2928
OK 2071
