New Posts New Posts RSS Feed: Seawych 19 mk1
Seawych 19 mk1
LittleFrank View Drop Down
Post Options Post Options   Quote LittleFrank Quote  Post ReplyReply Direct Link To This Post Topic: Seawych 19 mk1
    Posted: 07 Jan 15 at 11:32am
new owner of a seawych 19, unable to step the mast at the moment due to a missing part which prevents me from connecting the forestay to the deck, some kind of bottle screw device I believe, does anyone know the correct size or type needed, have tried 4mm and 6mm bottle screws without success,
rick
MerlinMags View Drop Down
Admin Group
Admin Group
Post Options Post Options   Quote MerlinMags Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 15 at 4:04pm
If you can provide a photo(s) of the two ends you're trying to connect, that might help someone advise you.
robinft View Drop Down
Post Options Post Options   Quote robinft Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 15 at 11:54am
Fix a shackle to the stem fitting and step the mast, securing the forestay to the shackle with a line. Measure the distance between the end of the forestay and the stem fitting (not the shackle). Take a photograph and the measurement to your local yacht chandlers. Simples.
DNA A-Class with Z foils GBR43
Post Options Post Options   Quote LittleFrank Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 15 at 12:51pm
Many thanks for reply, I'll,take some
rick
Post Options Post Options   Quote LittleFrank Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 15 at 3:49pm
https://onedrive.live.com/redir?resid=2E997DF8E97031EF!5060&authkey=!APA8t6aDpa4aVeA&v=3&ithint=photo%2cjpg
https://onedrive.live.com/redir?resid=2E997DF8E97031EF!5058&authkey=!AI3IgVPGztnJ0Xs&v=3&ithint=photo%2cjpg
https://onedrive.live.com/redir?resid=2E997DF8E97031EF!5061&authkey=!AL7-_d35Rgs4wMg&v=3&ithint=photo%2cjpg
hopefully 3 pictures of one end of a seawych forestay and its connecting part on the foredeck, middle fastener is missing
rick
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 15 at 4:07pm
Yeah, a bottlescrew. Perhaps an imperial size if its between 4mm and 6mm.
If you can locate a local second hand yacht parts emporium that might be the easiest option: take the bottom piece down and try loads until you get one that fits.
Post Options Post Options   Quote robinft Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 15 at 4:11pm
It's possible that the bottlescrew thread is unique to the cone type of rigging ends so perhaps you should look for a rigging shop rather than any old yacht chandler.
laser193713 View Drop Down
Post Options Post Options   Quote laser193713 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 15 at 4:54pm
http://www.stalok.com/p-494-machined-fork-sta-lok-unf-thread.aspx That is the fitting you have, you are missing the middle bit!
Post Options Post Options   Quote LittleFrank Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 15 at 5:20pm
Many thanks for the quick replies
rick
